Script help to set checkbox to true for Automation » Find Records » Run Scipt
  • Feb 24, 2023 11:59 AM UTC
  • 72 views
Forum|alt.badge.img+14
I have an automation that finds matching records for me and I, in the next step, need to update these records by checking a checkbox (true). As there are two or more records found each time I presume that I need to run a script to achieve this.
I'm a complete newbie to scripts; I have used readymade scripts, but never altered (other than to change name of table, view and/or field) or written one myself.
I have searched for an answer and even tested to modify found scripts with no luck. Could anyone help me with a script for this?
Table name: People
Checkbox field name: Sync
Great news!  You don't need a script for this anymore!
You can now use repeating groups for that, and so your automation would be: Find records -> repeating group -> Update Records and it'd do exactly what you needed!
Thank you @TheTimeSavingCo!
The things you miss when you're away for a little bit. Great to see that feature added and thank you so much for pointing it out to me. Works perfectly.
