Set automation with incoming webhooks
  • June 19, 2021
  • 134 views
Giacomo_Lanzi
I am trying to set an incoming webhook to create a new record.
When testing the webhook, it doesn’t work. I got a 404 response and the test gives me the following error: “This URL has not received any requests recently.”
That is happening immediately after I curl the hook.
anybody with the same error / situation?
Yep, I am getting the same issue even when I click the test link in the webhook automation UI.
Anybody else seeing this?
  • November 27, 2021
You’ll get an error 404 if the test data isn’t sent to the webhook in the proper format.
Ensure these things, which I pulled from the support article on webhooks:
  • Check that you sent a valid JSON payload. A tool like https://jsonlint.com may be useful.
  • To add multiple variables, make sure you properly format your content as a JSON object ( i.e. {"Company": "Airtable", "Name": "Testing"} ).
  • Check that your request was sent with a Content-Type header of “application/json”.
  • Check that you made a POST request.
Thanks, Scott. I’m all good after reading through the docs. It makes sense that it needs a payload to test.
