Setting up a Queuing System to an automation?
  • May 17, 2024 5:08 PM UTC
  • 186 views
I am running into the problem where if two users trigger my automation at the same time or before the automation finishes then the second data point will not run/create a record. Is there a way to setup a queuing system where the second trigger can hold until the automation has completed?
Thank you!
Dan_Montoya
  • Employee
  • May 17, 2024 6:18 PM UTC
You could consider a field that tracks Automation State.  Values might be: Not Running, Automation Running
Then on your when to trigger your two automations include that the automation state has to be Not Running.
  • May 17, 2024 8:17 PM UTC
Dan's idea is the best & quickest & easiest way to accomplish this. That's what I would typically recommend.
However, for a more complex way of handling this, you could outsource your automations to Make's advanced automations for Airtable.
In Make, there is a setting at the bottom of the automation entitled "Sequential Processing", which always ensures that your automation runs are triggered sequentially in order (so the next run won't start until the previous run is complete).
If you’ve never used Make before, I’ve assembled a bunch of Make training resources in this thread. For example, here is how you would instantly trigger a Make automation from Airtable.
