Simple Automation Won't Turn on
  • Dec 12, 2023 2:52 AM UTC
  • 20 views
I have a simple automation.  The test works fine but it clicking the "on" button doesn't work.
I've tried making new automations. They too have the same problem.
Any advice?
Thanks
Databaser
Forum|alt.badge.img+25
  • Dec 12, 2023 1:11 PM UTC
Is your trigger set properly? Can you share some more screenshots so we can see what you set up?
