Too many automations - monitoring them and single thread automation
  • August 22, 2023
  • 24 views
I have a base where each record in a table represents an exterior item. When the item changes in AirTable, I need that change to be pushed to the exterior database. I want to check the external file for each record every 30 minutes or so to see if the file has changed on the external system.
The code that I have implemented to do this is getting bogged down. There seem to simply be a backlog of automations to run. Even though I have turned them off, they are still running some time later and starting new ones seems to take forever.
Is there any way to monitor which automations are running and potentially stop them? What about any way of ensuring that only one incarnation of an automation is running at any given time?
