building a general ledger
  • Nov 4, 2026 12:11 AM UTC
  • 52 views
I operate a vintage restoration and sales practice, and while all of the items I restore and sell, and the repairs I do for customers, are already in well-established AT databases, I now want to build a simple general ledger to replace the Sheets file that just crashed on me. Are there any models out there?
You may want to check out Airtable’s Templates or the Airtable Universe for those:
  1. https://www.airtable.com/templates
  2. https://www.airtable.com/universe/search?q=ledger
I’d also be happy to jump on a free call where we’d just get right into building it together via screenshare if you’d like, and you can grab a time that works for you here!  I usually find that people’s workflows / business logic are pretty personalized to their industry / habits, and building something from scratch is faster than trying to adapt someone else’s system
Given that some of your business is already set up in various Airtable bases we’d look through those and see if it made sense to put the ledger in there or to create a new base and sync the required data over instead
greg_business_automated
​@Tim_Ettenheim  if you want to build it yourself, it would make sense to throw a few reference sheets to Claude, connect 1 airtable with source data and 1 clean airtable base using airtable MCP connector and first talk it out with Claude what would be a good setup.  It make sense to agree structure of the base first and ask it to minimize number of tables and columns to start with. All all tend to overproduce but it might be a good inspiration.
Other good options is obviously to get a consultant to build you a solid well structured data schema and use it as a starter point.
DLindsey
  • Nov 4, 2026 3:43 PM UTC
I also recommend using the Claude connector.  I am using it pretty heavily myself these days, and it’s very good at suggesting structure that I wouldn’t have thought of.  I’m also going to start using it to build automations, since those are time consuming, especially if they’re for relatively repetitive tasks that require different triggers.
CurtisFonger
  • Nov 4, 2026 4:37 PM UTC
I’d skip the template and model it as a journal. Three tables: Accounts (name, plus a Type single-select: Asset, Liability, Equity, Income, Expense), Transactions (date, memo), and Entries, where each row is a single line with an Account (linked record), a Debit and a Credit (both currency fields), and a link back to its Transaction. Add a formula field on Entries, {Debit} - {Credit}, and roll that up on Transactions as Balance; it should always be zero, so a formula like IF(ROUND({Balance}, 2) != 0, "⚠️ Unbalanced") and a filtered view will catch any that aren’t. Account balances are the same rollup on the Accounts table (flip the sign for liability, equity and income accounts so they read as positive). If you link Entries to your existing items and repairs tables, you can see the books per piece, and an automation can create the entries for you when a sale or repair is marked complete, so you’re not keying everything twice.
