Duplicating multi-base Airtable projects while preserving syncs and interfaces
  • Jan 15, 2026 7:27 PM UTC
  • 94 views
We use a standardized setup of multiple Airtable bases per project, with one base acting as a central master.
Example:
For project P1, Workspace 1 contains three bases: A1 (master), B1, and C1.
There are one-directional syncs from A1 → B1 and A1 → C1.
We want to duplicate this setup for a new project (P2) into a new workspace, resulting in bases A2, B2, and C2, while:
  • retaining the same sync structure (A2 → B2 and A2 → C2),
  • keeping all interfaces intact,
  • and minimizing manual setup or reconfiguration.
Achieving this would allow us to deploy a reusable, project-based Airtable application with minimal effort.
Hm, I don’t think this is possible at this time; you’d have to duplicate the bases and then set up the links again I think.  Might want to open a support ticket to confirm directly!
Interesting. I’ll try to give it a shot and get back to you with an answer soon. In the meantime, you’ll want to reach out to support@airtable.com as mentioned by Adam above.
YouTube Channel
