Grouping by Multi-select Help
  • August 24, 2020
  • 20 views
Hi! I am currently trying to curate panels by using a multi-select field to list all the panels and tag my records with people in them. Some people are selected for 2+ panels. In another view I am then trying to view my panels by using the group feature. The problem is if a person is a fit for two panels, it creates a new group. However I don’t really care if a person is on two panels (nothing is happening simultaneously). Is there a way to keep the grouping singular?
Avi_Doe
Forum|alt.badge.img+11
  • August 25, 2020
would be great if this would be possible. I am at the moment using the filter but the result is not really good. May be anyone here has a better idea?
