Import CSV extension doesn't work on synced Base
  • Aug 27, 2024 3:32 PM UTC
  • 128 views
Hi all!
I have a two-way sync enabled between two bases. On the source base I have enabled edits from the target base, and I am able to add individual records on the target base and have these show up on the source base. However, the Import CSV extension shows an error that says I cannot create new records in the target base.
I am 100% sure it's not a settings problem in the sync because I am able to add individual new records on the target base. Can anyone advise? Is this just a bug on the extension?
Thanks in advace!
Alex
Seems possible the CSV Import extension might not have been updated to handle importing into synced tables yet; might want to open a support ticket directly with Airtable to see if they have a timeline for this!
  • Aug 29, 2024 9:39 AM UTC
Thanks! I have submitted this to Airtable Support to see if they have feedback.
