Index of base tables
  • Jul 7, 2021 11:38 AM UTC
  • 209 views
Shaun_Parfett
Forum|alt.badge.img+11
Hi all. I have a base with 12 tables. I would like to create a table which will list links to all the other tables in the base, to ease navigation. I can get the View link but that opens up in a browser. Is there a way to create a link to a table that then goes to the referenced table within the desktop app?
Thanks in advance.
Shaun
Best answer by Justin_Barrett
No. The desktop apps are effectively dedicated browsers that only connect to Airtable. If they generated app-centric links, those links wouldn’t be usable when trying to access Airtable from a browser. It’s a bit of an annoying catch-22.
If you’re open to using keyboard shortcuts, try the Ctrl-J (or Cmd-J, depending on your OS) hotkey. That opens the table browser, where you can either click on the name of the table you want to open, or type part of a table name to narrow down the list, cursor to it, then hit Enter. It’s the next-best thing to an always-open table picker for now.
Shaun_Parfett
  • Jul 7, 2021 10:05 PM UTC
Many thanks and much appreciated Justin. I suspected that this was case, but hoped it wasn’t.
