Ipad Scrolling problem
  • November 16, 2020
  • 35 views
Just recently I, as the Owner, and other simple “viewers” cannot scroll down or sideways when using an ipad. I see others have posted here but, I don’t see a solution. Is here a work-around? For me, this seems to be a new problem. Thanks!
Forum|alt.badge.img+20
  • November 16, 2020
Hi @Thomas_Luter
Are you using the desktop version on your iPad or the Airtable app?
If you are using the desktop version there is limited capabilities, i.e. scrolling issues.
Hope this helps.
Mary Kay
