Live base design webinars starting April 6
Forum|alt.badge.img+20
If you’re not sure how to get started with designing your base, our resident Airtable experts are currently leading 45-minute trainings for the use cases listed below. Each training starts from scratch and walks you through the motions of building a ready-to-use workflow within your base.
If you’re interested, just fill out the form and select your preferred time slot — no Airtable experience is required to join!
