Music Ontology - how to create a base using an existing schema
  • January 4, 2021
  • 34 views
HI there,
I am trying to set up a music library and would like to use the standardised music ontology that exists: (musicontology.com / https://github.com/motools)
Is there a way of using an existing schema and importing it in to airtable to create the relational database without having to recreate it by hand?
