Rental management - base, apps, automation?
  • January 21, 2021
  • 153 views
Dear AT Community,
I own/manage a few rental units and was looking for online software for managing them (ie organize, make life easier). Figured I check AT for a template, base, apps, and automation. Surprisingly (and disappointingly), can’t seem to find anything. Saw one base someone created but it’s for short-term rentals. Is there anything out there that I have missed? Checked Templates, Marketplace, Universe. If not, any suggestions where I should look to start building? I’d prefer to not have to subscribe to yet another app and keep this home within AT.
TIA, Regards,
Sunny
Hi ​@sunny11,
Yes, those are the key places to look for Airtable templates!
It sounds like you might benefit from working one-on-one with an Airtable consultant to help you build & customize the perfect Airtable system for your needs.
If you have a budget and you’d like to hire the best Airtable consultant to help you with this, please feel free to contact me through my website: Airtable consultant — ScottWorld
Also, here are some 3rd-party tools that might be useful for you:
  • DocuMint or DocsAutomator to create professional documents from Airtable.
  • Make to handle advanced automations or integrations for Airtable.
  • Fillout to create advanced forms for Airtable.
Best,
Scott
  • January 22, 2021
Hi @sunny,
It sounds like you might benefit from working one-on-one with an Airtable consultant to help you build the perfect Airtable system for your needs.
If you have a budget for your project and you’d like to hire an expert Airtable consultant & Registered Integromat Partner to help you create this, please feel free to contact me through my website at ScottWorld.com.
Best,
Scott
Thank you as always @ScottWorld, I’ll check out your site
  • July 18, 2024
Hi Sunny - did you get this worked out? I'm also in the market for a basic tenant application/form and possible rental expense tracker. Thanks.
