suppliers products
  • Jun 3, 2026 5:54 PM UTC
  • 122 views
I build 3 tables:
First table for suppliers: supplierId, supplierNmae.
Second table for products: productId, productName
Third table for the link between suppliers and products: supplierId (link to suppliers table), productId (link to products table), price (the price of the product that supply this product).
In relational data base that what I need to buid.
Is that what I need to do in Airtable data base?
DevonK
  • Jun 3, 2026 7:23 PM UTC
You can link the suppliers and products tables directly without a joining table. Just create a new field in products, choose the field type “link to another record”, and select the suppliers table.
If each product can have multiple Suppliers and different prices then yeah you’d need a third table called ‘Prices’ or something where each record represents a single Product for a single Supplier
If each product can only have one Supplier and one price, then just the Suppliers and Products table is fine
  • Jun 4, 2026 10:14 AM UTC
No, I dont think so.
I think you wrong, because the price of first supplier is differnet from secod supplier.
In relational data base we must add a table with the fields: PK of suppliers, PK of products, price that present the price acording to supplier and product. The primary key of third table is PK of supplier + PK of product.
Am I worong?
  • Jun 4, 2026 10:19 AM UTC
Dear  (Sorry, but I dont know your name),
I think you right and I must have third table.
Thank a lot
