A little help with a script to trigger a webhook
Show first post
siliceous
Forum|alt.badge.img+10
  • November 14, 2022
Hi @Justin_Barrett
Thanks for this awesome thread. I am trying to get the output on running a script that gets the folder names in Clickup, but I can’t seem to get the output code to work.
The code from Clickup’s API works when tested:
const query = new URLSearchParams({archived: 'false'}).toString();
const spaceId = 'YOUR_space_id_PARAMETER';
const resp = await fetch(
  `https://api.clickup.com/api/v2/space/${spaceId}/folder?${query}`,
    method: 'GET',
    headers: {Authorization: 'test'}
const data = await resp.text();
console.log(data);
but the output.set code doesn’t seem to fit in anywhere (red error). I’ve tried variations of the code but it isn’t successful when testing. Does anyone know how I can get the output with the code above?
Hi @Justin_Barrett
    method: 'GET',
console.log(data);
Please share an example of what you’ve tried so far. It’s hard to know what to recommend without seeing what you’ve already attempted.
siliceous
  • November 15, 2022
Hi Justin,
What I wanted was to do was to output the response of the script and I’ve managed to figure it out. Thanks for taking the time to reply.
  • June 30, 2023
Welcome to the community, @KMU_Project! :grinning_face_with_big_eyes: Did you create a recordID input variable and assign it to be the record ID of the triggering record?
I have this exact same issue, how do I create a recordID input variable for the record ID of the triggered variable?
Thanks
