Help with "INVALID_PERMISSIONS_OR_MODEL_NOT_FOUND",
  • Mar 4, 2024 1:33 AM UTC
  • 132 views
I can't find anything wrong. My access token has everything:
When I try in postman i always get the error above. This is my post request:
Yet I always get this error message:
Help please? 🙂
Hm, could you try doing the request one field at a time to see if a specific field is causing the error or if it's happening with all fields?  May I also know what the field types are that you're updating?
dilipborad
Forum|alt.badge.img+23
  • Mar 5, 2024 5:10 AM UTC
Hello @chabacano2 ,
I've got the same issues for a couple of days. After these token-based auth implementations in Airtable, this error comes for many old settings URLs.
But this is a simple one please change Table Name(Users) to Table ID(tbl****).
I think it will fix.
