I need help with my scopes
  • February 11, 2026
  • 74 views
I keep getting this message and ive done this same thing a bunch of times before:
{{Make sure you enabled the following scopes for your token:
data.records:read
data.records:write
schema.bases:read
 Its kind of hard to miss these exact words while comparing them slowly  to ensure accuracy. It just wont attach the scopes to my api token. Im not sure what in missing and i should not be missing anything, its pretty simple to do as ive done before so what changed now when i have changed nothing?
Hm, if you could tell me what you’re trying to do and where you’re facing this error I could try replicating it for you if you’d like?  Could you provide some screenshots of what you’re seeing?
​@Jerome B,
Are you still getting this issue?
I’d be happy to hop on a 5 min call and try to help you out. Feel free to grab a slot using this link.
Completely different matter, but would love to have you join the March 2026 AT Community led Hackathon! Make sure to sign up!!
YouTube Channel
