Stuck on "Step Pending" when running a script through automation
  • February 21, 2023
  • 141 views
This is happening on trigger from record creation, another script triggering a webhook, etc.  The automation just hangs on the first script step endlessly.
I've confirmed that the script executes successfully when run by itself.  According to status.airtable.com everything seems fine.
Anyone have an idea on what might be the issue?
That's a weird one.  I just tested running a script and it worked fine, so I'd chalk it up to weirdness on Airtable's side, and if it's still happening I'd open a support ticket if I were you
  • February 21, 2023
Yea, guess it was some quirk yesterday?  seems to be working now.  Thanks for the response.
