How do I get the Quotes to not show when using a formula for re-using a field output
RonniEloff_VKDe
I have a lookup field that I use to pick what Client the new record in my Activities Base is for called Contacts
It auto populates the field record properly when I select the new client
However because you can't have the first field contain a Lookup (DUMB BTW especially for rollups and such) I have to put a formula to use the data from the lookup field record to do the rest of my workflow for the client
It is putting the information in "" (see graphic) (Client field)
It did not do that when I just used the old fields of First Name /Last name when I concatenated them (Concatenate field) which used to be the way until we moved into a separate table for Contact information
Is there something I missed in setting up the Account name field or the Contact Field to prevent the " " (quotes) from being shown?
Best answer by Ben_Young1
Hey @RonniEloff_VKDe!
Give this formula a shot:
IF( AND( {Contact}, NOT(LOWER({Contact}) = "unnamed record") ), REGEX_REPLACE( TRIM({Contact}), '["]', "" ) )
Ben_Young1
Forum|alt.badge.img+22
RonniEloff_VKDe
Thank you.  That worked very well.  Now I have a dashboard that looks right for the Client too 🙂  It does seem strange that you have to regex that but I can see why I didn't think of it...cause I didn't think it would be doing something like this.
The reason why the quotes appear is because there is a comma in your contact name and the formula is taking the contents of an array. When Airtable converts and array to text and an individual item has a comma or quotes, Airtable adds the quotes so you can differentiate the individual item. Airtable even does this when there is only one item in the array.
There are several possible formulas for removing the quotes. Most people use a straight substitution of the quote character with an empty text string. Note that if you ever have quotes that actually belong in the text and want to remove only the extra quote, you will need a more robust formula.
RonniEloff_VKDe
I completely forget these things after I set up the contacts table.  It's a concatenated field (of First/Laste Name) that I am using for the lookup from that table.
I need to remember that these things.  Thank you for taking the time to reply.
