When criteria is not met, leave field blank (help)
  • March 23, 2023
  • 41 views
Forum|alt.badge.img+11
Hello everyone!
I have this formula:
IF(AND(DATETIME_FORMAT({Trækdato (FarPay)}, "D")<10, DATETIME_FORMAT({Dato for udløb}, "D")<10), IF(WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"))=3, DATEADD(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"),1, "weeks"), IF(WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"))<3, DATEADD(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"),3-WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD")),"days"), IF(WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"))>3, DATEADD(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"),10-WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD")),"days")))))
Currently when the field 'Trækdato (FarPay)' is empty, it will give an '#ERROR!'. I want it to just leave the field blank. Is that possible?
joshsorenson
Forum|alt.badge.img+9
  • April 14, 2023
Try this, basically, you need to tell it if the field is blank to return the empty value.
IF({Trækdato (FarPay)}=BLANK(), BLANK(),
