Airtable Timeline Interface not updating color by condition
  • Jun 14, 2024 12:06 AM UTC
  • 106 views
Sergej_Gastilov
One Relative Table "Booking" to a Timeline View of another Table "Front Desk" has a Rollup Field "Error": "IF(COUNTALL(ARRAYUNIQUE(values))=1, FALSE(), TRUE())", which calculates if was error or not.
Interface of a Timeline "Front Desk" is not showing correct color by a condition. Airtable Table works fine. Only a issue in Interface. Thanks.
P. S. When I update values in a Table, Rollup field calculation is correct. Interface works only at the beginning, after - no changes (color stays the same).
In Interface in DevTools during resizing of Timeline i see such errors...
and Rollup Field looks like that
Hmm I just tested coloring a timeline by condition in both a view and in the Interface and both worked fine
If you could you provide a read only invite link to a duplicated copy of your base with some example data I could take a look at it for you
https://support.airtable.com/docs/adding-a-base-collaborator#adding-a-base-collaborator-in-airtable
YousufIdris
  • Aug 13, 2024 7:18 AM UTC
I'm having the same issue. Here's a Loom video with a good explanation of what's going on. Any help is appreciated!
https://www.loom.com/share/6690d90b80f044d6910db33fc16883ea
Roger!  I saw your thread and replied there
