Help to create the right view
  • August 25, 2023
  • 35 views
Hi all,
We are looking to find out if it is possible to create a table view that follows the pattern in the screenshot.
We tried using lists but it only gave 1 layer of information, for the second layer there needs to be a new Table of contents, however, all our content is located in one master info sheet that is populated from a form.
How can we achieve this view? Also maybe there is a way to create a personalized UI ?
Thanks
Take a look at the grouping button in the toolbar.
Also, since you are new to Airtable, you might benefit from taking my free Airtable training course, which you can take for free by signing up for a trial membership with LinkedIn Learning.
I discuss grouping in my course:
https://www.linkedin.com/learning/learning-airtable/
