How to print a dashboard page without cutting of half the content
  • November 22, 2024
  • 131 views
Kim_Trager1
Forum|alt.badge.img+23
I have an interface with a dashboard with two pivot tables tracking budgets.
I have a dashboard page set to allow printing; however, every time I print, one of the two pivot tables are cut off although they both fit on the page, and there is no horizontal scroll needed.
I've tried to expand the table and print them one by one, but then the same cut-off still happens.
This is how the pivot tables look on my screen only - only 5 columns to print:
This is how it looks on an A4 page - where the two last columns are cut off:
Does anyone know how to get these two pivot tables to actually print out so the printout is usable, or is it a bug?
Dimitris_Goudis
Forum|alt.badge.img+20
Hey @Kim_Trager1,
Did you try to update your printer's settings on the page? The quickest is to add printing on the landscape. If this doesn't work please try to update margins on the page.
Kim_Trager1
Hey @Kim_Trager1,
I actually figured it out. The width of the appearance width of the group has to be set to narrow, not ideal and quite limiting, but at least it gives some parameters to work within.
