Interface - Click Into Record Details Issue
  • August 19, 2024
  • 13 replies
  • 551 views
At roughly 4pm EST 8/19/24 none of my users, including myself (admin) could no longer click linked records to see the detail screen for the latest (non-legacy) interfaces I have built.  The legacy interfaces still allow for linked records to be clicked into detail screens.
It was working fine one minute, no changes to the interface were made, then the links simply stopped showing the flyout windows when the records were clicked.  When editing the interface and selecting the link destination it gives you the icon to test the flyout of the link and that does not work either.  Nothing at all happens when clicking the records.  No settings were updated or changed.  When I dug into it I did find that I could update my layout I was trying to click into and "Upgrade it out of legacy", however, when I attempted to do that it froze the page up and never was able to accomplish the upgrade.
It feels like an update went out that accidentally caused this issue.  Hoping that Airtable support sees this and looks into it.
Looking for anyone that can replicate on their base and provide any additional info so I know if this is an Airtable bug or a feature that I don't know how to configure.
cvoith
Forum|alt.badge.img+14
  • August 19, 2024
I am also having this issue. It's so far only for some people on some interfaces. It's also on non-legacy pages, with the records in linked tables. I reached out to support for help, hopefully they fix this ASAP.
  • August 20, 2024
The same issue is happening with me and all other users in the enterprise.
Ruben_trd
  • August 20, 2024
Same issue here with non-legacy Record Review layout
  • August 20, 2024
I have flagged this post and issue internally (I noticed it myself today). To clarify, with the non-legacy record viewer, the record details flyout appears correctly when in design view and preview but not for users working with the published interface?
Ruben_trd
  • August 20, 2024
Nice, thanks,
For me (admin) the flyout doesn't appear either in design view and preview
And not showing for the users working with the published interface
  • August 20, 2024
Nice, thanks,
It's the same for me.
  • August 20, 2024
For everyone following this thread, an escalation has been created in Airtable for this issue. As and when I see updates I will post here as appropriate.
  • August 20, 2024
Issue should be resolved - fix was put into production and I can confirm that it is resolved in my base/app (I did have to force a refresh in the browser).
Should you continue to experience issues then I would recommend logging a support case in the first instance.
  • August 20, 2024
Confirmed it is indeed resolved.  I wanted to thank your development team for addressing this and resolving it so quickly.  Major Kudos to everyone involved.
  • October 15, 2024
I just discovered that this bug is back!
  • December 11, 2024
I am having this or a very similar issue. I have linked records displaying in an interface. I have set "click into record details" as true and created the view of record data I want displayed. This works fine in edit mode and via the app, but when published as a shared public interface the click through is simply non functional.
  • December 11, 2024
It sounds unorthodox I know but I have sometimes found that if you toggle the "Link/Unlink" and the "Click to Open Records" fields in various orders (1 then the other, both at same time, etc.) it has fixed the issue you are referring to.  Once the issue is fixed, you can set those toggles to what you actually want them to be.  If it doesn't fix it for you they may have another issue similar to the one I started the thread with.
  • December 17, 2024
I think this may actually be the first time that I have found a chatbot to have an answer to a question!
This answer does feel a bit bogus. Surely it is up to the interface designer to decide what level of record detail is appropriate? However, I can now move on with my life.
