Interface comment section not loading
  • January 30, 2024
  • 254 views
Does anybody know why the comment section in Airtable interface is not loading/ working properly? This has been happening in multiple bases since a couple of weeks and I'm wondering if there is a fix for this bug.
Forum|alt.badge.img+12
  • June 4, 2024
We have this same problem -- just a spinning ball -- it's been happening for months.
  • September 24, 2024
I'm having the same problem, so it's very inconvenient.
comment area errors occur frequently..
When I copied the base and ran it again, it worked normally, but after 4 days, it's the same again.
  • October 31, 2024
This thread was started in January and here I am in October. I created a brand new Airtable account intending to use it for project management, but the fact that comments on tasks don't work is a dealbreaker? Why is this still broken? Not just in the interface view, but in data view, too. I added two comments to a task. Spinning circle, comments won't load/show.
Screenshots to show that I'm viewing a task with two comments in the interface and data views of Airtable and getting just a spinning circle where the comments should be.
EDIT: Ok, I kept messing with settings and I set user filter elements to "none" and now the comments are showing. I'm not sure the two things are actually connected, but I'm pretty sure that's the only thing I changed in my interface page view?
EDIT 2: Never mind, that was a short-lived celebration. They're back to not loading.
Forum|alt.badge.img+7
  • February 20, 2025
Greetings. We are also having the same trouble, and it seemed to have started earlier this week, 2/17.  Is this a known issue?
Noah1000
  • March 28, 2025
Hey guys, I found a fix that might work for you too.
I had this browser plugin installed, that blocks cookie consent banners. After adding airtable.com to the whitelist and accepting cookies, the comments started to load correctly again.
So this issue seems to be connected to the cookie consent. If you interfere with that in any way, check if removing that solves the issue.
Hope this helps ✌️
