Interface Toggles/Controls (collapse/uncollapse) other than sort & filter?
  • Dec 7, 2023 7:27 PM UTC
  • 182 views
I have some interfaces where list views are grouped by client name.  I would like a "collapse all" or "expand all" function so that in those interfaces, it is possible to quickly expand all the lists or collapse them and then go one-by-one.  The only "global" controls that I see are filter and sort.  Are there others, or some way to do "collapse all" and "expand all" elsewhere?  Thanks.
Best answer by Sho
They are in the right-click menu.
Forum|alt.badge.img+24
  • Dec 8, 2023 12:05 AM UTC
