Missing info when downloading csv from Interface with 2 levels of hierarchy
  • June 18, 2024
  • 91 views
I have an interface set up showing our contacts and associated interactions with them. There are two levels of hierarchy. At the top (Level 2) is "People" and under that is Level 1 "Interactions". These levels are linked by a common Interactions column. I've enabled the download .csv option.
However, the resulting .csv file only reflects the shown information on the "Interactions" level (level 1) and shows none of the info from "People (Level 2). What am I doing wrong?
To help illustrate, my Interface List could look like the one outlined below, but in the .csv file, only the info related to interactions will show up (with the correct corresponding column names).
^ Person A Name              Person A Email
       Interaction Name            Interaction Type            Interaction Date
^ Person B Name              Person B Email
^ Person C Name              Person C Email
New to AirTable and would appreciate any feedback! Thank you.
  • August 21, 2025
I have the same issue. It definitely seems like an Airtable oversight. But after a year of waiting, I found a workaround:
  1. Enable Grid mode for the interface before publishing.
  2. Switch the view from List to Grid.
  3. Export (this will give you Level 2 data).
  4. Switch back to List mode.
No need to edit the interface itself.
