No longer able to create Interface from Base view
  • Oct 20, 2026 5:15 PM UTC
  • 86 views
Jasmine_Ruth1
Forum|alt.badge.img+9
So Airtable decided to remove the option to create an interface from a base view? Why? Another nonsensical random change that is a time suck on this new system. We used to be able to create an interface view based directly off a view in Airtable, this was a great feature that no longer exists on any of the newer bases and only available on the grandfathered bases. The way Airtable does this makes things very confusing. Because then you have some bases performing one way with some features and other bases performing completely differently just depending on when the base was created. I’ve even come to report things here and people have been confused, saying “this still works for me” because they are using a base created before the change. I submitted a request that I hope they change this back.
anthonyXRay
  • Oct 26, 2026 1:21 PM UTC
It sounds like you might be hitting the difference between the older and newer bases.  A few people in other threads have noticed features behaving differently depending on when that base was created, so that’s probably why others say it still works for them.  I haven’t found anything official on if it is intentional.
As a workaround, you can build the interface page directly and add a grid or list element to it.  Recreate your view’s filters, sorts and visible fields there, so that it behaves like the view that you wanted to start from.  It is more clicks but you get close to the same result.
If you haven’t already, it is worth posting it in Product Feedback too so that people can upvote it.
ibay
  • Community Manager
  • Nov 1, 2026 9:57 AM UTC
Hi ​@Jasmine_Ruth1 so this isn't a deliberate removal, but there is an inconsistency.  ‘Start from a view’ lives in our older, element-based interface pages. When interfaces moved to the newer layouts (List, Grid, Kanban, Calendar, Gallery, Timeline, Dashboard), that option wasn't carried over, so it depends on which page system a base is on, which in practice tracks when the base was created. That's why it still works for some people and not others, sorry about the frustration.
It's still there in two places: if you start from a Blank page, the grid or list element you add has "Copy settings from a view"; and the Record review layout's setup step still lets you copy a view's filters, sorts, groups and visible fields.
For a List or Grid page, the workaround mentioned by the ​@anthonyXRay  above is the right one, thanks for the input there.
It is more clicks than it is ideal, as said, so I'm passing the feedback on to our Core product team. Thanks for flagging!
