Using Interface Filters for Automation Find Step
  • Oct 28, 2026 8:26 PM UTC
  • 67 views
Are there any options to filter a list of employees on an interface dashboard layout and then trigger a repeating automation to email only those who match my filters?
I want to be able to specify through filters something like: “only employees who have completed training 1, but not training 2, but also have a last name containing a G” and then email those employees through a button triggered automation. I need to be able to change the filters somewhat often and set the automation to run on different groups of employees.
phoebelindo
Forum|alt.badge.img+10
  • Oct 28, 2026 8:52 PM UTC
There isn’t a way to use the filters as a condition for an automation BUT I think you could make a makeshift version within a Blank interface.
  1. Create a checkbox field and expose it in a Grid/List on the Interface.
  2. Filter the records however you’d like.
  3. Once your filters are set, check the box for all visible records. A Grid would probably work best since you can copy/paste the checked value down the column.
  4. Add a Button element that triggers an automation to:
    • Find all records where the checkbox is checked.
    • Run the desired action for those records (e.g., send the email).
    • Uncheck the records once complete so you can reuse the workflow later.
For this solution you’d need to configure the Button element to a specific Dropdown element for it to be able to run an automation. I’d suggest basing it on whatever email template you’d like it to run.
DisraeliGears01
Forum|alt.badge.img+22
You can use data view filters as a condition for an automation, but not interface filters.
If you have access to the data side, just make a grid or list view called “To Email” or something. You can apply whatever filters you like to that view to create a subset. Then create an automation that triggers on when button is clicked→ Find Records in Table based on view “To Email”→ Repeating Group action to email all records in Found Records list.
So in the end your workflow would be in the data side to filter your list down, then go over to the Interface side and press the button in whatever interface page you want to put it.
Leo Luo
  • Nov 3, 2026 2:10 AM UTC
Hi ​@rec-RISKMGMT ,
Airtable's Core Product team literally just rolled out an official update today that directly addresses this workflow without requiring you to switch back to backend views or check boxes manually:
  1. "Run automation" buttons can now be placed directly on Interface List and Grid pages (not just on single-record detail pages).
  2. The "Find Records" action limit in Automations has been increased from 1,000 to 4,000 records.
How to set up your workflow now:
  1. Set up a grid or list element on your Interface page where coordinators apply your desired filters (e.g. Training 1 complete, Training 2 incomplete).
  2. Place the new "Run automation" button on the interface.
  3. Configure the underlying automation with the expanded "Find Records" step targeting those same criteria, followed by a "Repeating Group" to dispatch your notification emails.
This allows you to work strictly within the Interface layout while backend automations process the batch cleanly.
