Using interface with barcode field for stocktaking
I am hoping to use a cutdown “form” or interface designer method to enable stocktakes of our database items via mobile phone and the airtable app. I have created an interface with a barcode field to be used as a key to all the items and an associated display of the fields for each record that can be changed - location, number of items etc. As others have mentioned I was surprised ot see that sharing the interface also shares the entire base but this doesn’t worry me as its only for internal use. When I look at the barcode field for the base/table on the phone app, I can see the camera/scan option and can scan in a barcode. But when I launch the interface and see the barcode field, I can’t see a camera option. If I select the barcode field it just shows a screen keyboard and I can’t see how to enable the camera. I want to use the camera/barcode to find the item in a record list then manually enter the associated data.
Also there doesn’t see to be a way to access the interface from the mobile app. I have to use the sent share link to get to it.
Forum|alt.badge.img+16
Hi @Jill_Holland,
As far as I know the only way to scan barcode is on the Airtable Mobile app and at this time the interfaces are not part of the app though a link will open an interface in the mobile app, YMMV.
  • August 12, 2022
Hi @Jill_Holland,
Thanks Vivid. Thats how it looks to me too. I don’t want to collect the stocktake data using the whole table as it has about 50 fields and I only want to update 4 with the mobile interface. Maybe the form view would work ?
Yes, this is the exact intention of views.
Taha-Jiruwala
Forum|alt.badge.img+9
Instead you could check out the QuickScan extention. With this extention, you can connect an external barcode scanner to your laptop/tablet, scan items continuously, and have the extension automatically search and update the right Airtable records.
You can configure which fields to update before you start scanning, making the entire process smooth and incredibly fast.
