What's your favourite way to create a scatter plot with labeled data points using your Airtable data?
BuildForAT
Hello community,
From my understanding, Airtable’s native scatter plot doesn’t allow you to plot individual data points. It only allows you to plot an aggregation for each x-value. Therefore, it also won’t allow you to associate a plot point with an individual data record.
I know there’s a way so that the user can click a plot point and see the records associated with the point but what I want is for each plot point to have a label beside it (the name of the record).
Here’s what else I’ve tried so far:
  • Softr.io - but I encountered the same problem (it only allowed me to plot aggregates)
  • quickchart.io - it works! but it doesn’t have that clean, professional feel
So, what’s the best way in your opinion to create a scatter plot with Airtable data?
Here’s a summary of my requirements and goals:
  • Must be accessible in the Interface
  • Must have data labels for individual records
  • Would like it to be as easily accessible as possible. Having the chart be embedded into the interface so that the user doesn’t have to click anything is most ideal (but may not be possible). The fewer clicks the better.
  • Would like it to be easy to setup. This is for a tool that will be separately setup for individual businesses.
  • Would like it to feel clean and modern.
Thank you all in advance!
You wouldn’t be able to do that from the interface layer, but you might be able to do that from the data layer with either the chart extension or the Vega-Lite extension.
In the FAQ for the chart extension, it talks about overlapping data points on a scatter chart, and it also recommends using the Vega-Lite extension.
Coming very soon to Airtable — probably in 2025 — extensions will be able to be embedded into interfaces.
However, extensions will need to be updated to support embedding within interfaces. So if you can get what you want with one of these 2 extensions, then hopefully Airtable will update these 2 extensions shortly after the rollout of interface extensions!
BuildForAT
The chart extension does allow me to create non-aggregated scatter plots!
It will also show the name of the record if I hover my mouse over the point, which is close enough.
Do you have any sources that I can cite for when extensions will be available through the interfaces? That’s super exciting!
Nice! That’s great to hear!
Airtable hasn’t given a release date for interface extensions yet, but they’ve been posting about it on social media.
Here’s one of their posts about it: https://www.linkedin.com/posts/airtable_were-excited-about-the-possibility-of-our-activity-7329243203247788032-swgq
You can also sign up for their alpha testing of the new feature through the link in that post, but note that the alpha testing is for developers who want to convert their existing extensions to become an interface extension (or developers who want to create a brand new extension as an interface extension).
Hope this helps!
Hey ​@ScottWorld did you get to see any other demos on interface extensions?
Video on the post is the only thing I’ve seen and would love to see other examples :D
No, I’ve only seen private demos. But Airtable is encouraging their partners to post social media videos about it, so maybe you’ll be able to hunt around and find some!
Got it!!
