Ability to create custom blocks
  • February 12, 2020
  • 59 views
Like many others i found Airtable a very fancy way to create my own movie database solution, but since i have many items for adding to table i was think about some kind of automation. i tried zapier but that was not what i’m looking for. my idea exactly is like the process of adding a movie to imdb lists, by typing some first character of movie title a drop-down list shows then by clicking the item information automatically implements. in my opinion the best way is block that connect whit omdb API and fill the table filed. so what do you think? is there a better way for this goal?
Kamille_Parks11
Forum|alt.badge.img+27
Check out this example for the beta of the Scripting Block:
  • February 13, 2020
Thanks Kamille, i didn’t know about script block at all it provides high flexibility. i requested for developer access.
