Add custom restrictions to Blank Page interface's Filter element
  • Feb 13, 2025 7:59 PM UTC
  • 57 views
Forum|alt.badge.img+10
I have a Blank Page interface that's a Filter element + Calendar view that's meant to show how one type of resource is used by four different teams. The Filter element under Blank Page is really nice, since I can restrict to Team > Is > {pick a team}, and some filter on Team will always be applied. However, if someone viewing the calendar wanted to, they could change the operator to "Is not empty" and get around the filter settings. I need the calendar to only show one team at a time, because the resource usage display is unhelpful otherwise (plus some related social/work culture reasons that a "one team at a time"-specific filter would solve). Additionally, while there are 20+ teams that use this resource, only four of them are actually relevant for this calendar, so restricting the list of options of pickable teams would be ideal.
Can we get custom restrictions on the Filter Element in blank page, so that we can limit which operators and options are available to the end user?
Yeap, being able to limit the selectable options in a dropdown would be great.  For your issue, perhaps you could use a linked field for your teams instead?
This works by filtering the initial Interface to only display Team 1 and Team 2, and that makes only those records selectable in the filter
And I've set it up here for you to take a look at
