Base Schema Extension Improvements
Jason_Knighten1
Forum|alt.badge.img+15
To whom it may concern,
An enhancement suggestion from Kalypso: Improve functionality for Base Schema extension (See screen shot for Kalypso base configuration).
  • Currently with our base, it is challenging to follow highlighted relationship mapping lines even with the filter capability
  • Enhancements might include:
    • Right click on dependency line to see details of the dependency in a pop up (What dependency type, table and field names on each side of the dependency)
    • Use different colors to represent different dependency types
    • Ability to separate the tables with either a drag drop or pre-configured distance options
Expected Benefits: Improve the ability to use the base schema for its intended use to visualize table/field relationships.
Reference screenshot
Please consider adding this capability.
Regards,
Jason Knighten
