Fix bug for conditional automations with lists of objects
  • Jan 28, 2025 3:17 PM UTC
  • 24 views
What is the proposed idea/solution?
Parse linked records and dropdowns as lists, or change trigger to use "is exactly" (object) instead of "contains" (string)
How does it solve the user problems?
The current workaround is to create a formula field that is the string copy of the object field, but this does not allow complex conditionals (such as NONE OF or EXACTLY).
How was this validated?
Solved: Condition failing when using contains and the fiel... - Airtable Community
Who is the target audience?
Airtable Community
