Gantt for Resource Management
  • June 24, 2020
  • 26 views
I really like using 10,000ft tool for resource management. It would be awesome if we can enhance the gantt block to do something similar where you have quick way of seeing if a resource is over-utilized and where we need to adjust.
Bill_French
Hi Michelle, and welcome to the community!
This is actually possible with the new Vega Lite Block that’s in beta. While this example is pretty simple, the beauty of Vega is that it supports deep customizations with a little learning and experimentation.
Use the link in this article to add yourself to the beta instantly and then give it a try.
