Interface - Make features more consistent across all interface 'types'
Michael_Andrew
Forum|alt.badge.img+23
What is the proposed idea/solution?
Currently, there is significant differences in features across the different interface 'types'.  Even among the 'elements' there are differences.  For example, you can have a 'list' type (which has 'sort'), but if you add a 'list' element to another type (e.g. Dashboard), you don't get same capabilities (e.g. 'sorting', 'hierarchy').  It's as if all the 'types' are developed separately, and new features are not retroactively added to 'old' types.
How does is solve the user problems?
These inconsistencies in look and features are frustrating to builders who would expect that features are similar across elements.
Amen! 🙏
Michael_Andrew
I would add that the feature to download csv file should also be available on any list view regardless of interface type.  It's frustrating to be able to do it in one style, but not in the other.
