Load to Single and Multi-Select Attributes with csv or xls
Jason_Knighten1
Forum|alt.badge.img+15
To whom it may concern,
An enhancement suggestion from Kalypso: Add ability within single and multi-select attributes to load via csv or xls file.
Expected Benefits: Improve efficiency and accuracy when needing to load long list of values.
Please consider adding this capability.
Regards,
Jason Knighten
You can’t do this directly into the field options, but you can do this indirectly by importing your CSV/Excel file into your table as records (i.e. map your column into the field in question), and then delete all the records that you created afterwards.
Hope this helps!
Jason_Knighten1
Agree that is a viable workaround and I have used it in the past. The ask is to be able to import to individual fields. It may be unlikely to be accepted/developed by Airtable but a guy can dream. 🤔 🤔
