More robust interface design options
  • April 28, 2023
  • 31 views
What is the proposed idea/solution?
It would be great to have more design options for fields in interfaces. Some examples:
  • Center text within a text box
  • Center elements across the whole page
  • Change the thickness and color of dividers
  • Add a spacer option (this would be solved by the above by just doing a white line and increasing thickness)
  • Center the number and text within a number element
The first 2 above have been giving me the most headaches. Having to add blank text boxes of varying length and adding spaces inside text boxes just to center the text or other elements on the page seems excessive. I feel there could just be a center button in both menus (the one with text-specific options and the one that allows you to change the color for multiple elements/extend them all the way across the page).
How does is solve the user problems?
Allows users to create more professional-looking interfaces in less time
How was this validated?
Who is the target audience?
RonniEloff_VKDe
One more thing I would like to see is that the Buttons have a < and nothing for additional visual options.  Currently they only support > - which is giving the wrong impression for a multi-page navigation.
For example I want Home to not have > - Just the word Home
And buttons Page 2 & Page 3 to show
< Page 2
< Page 3
