Nested Tabs per Base
  • February 27, 2018
  • 11 views
I have several tables that have to split large amounts of data into separate tabs, I’ve found that I have a crazy number of some tabs because the data isn’t relevant to each other, but needs to be linkable – gotta keep it on the same base.
That being said, it would be extremely useful if I had the ability to condense groups of tabs by assigning them ‘folders’ that would hide sets unless clicked on. It doesn’t need to be an automated parent / child nested table set, but at least having the ability to group sets of tables by a simple check box would be very useful for me.
