Nesting conditinal logic and repeating group actions in an automation
  • Sep 6, 2024 2:52 PM UTC
  • 72 views
Pascal_Gallais-
Context
Within an automation we use a repeating group action to update a set of records. We may want to update each of these records differently depending on a condition.
Currently, we need to define several automations to do that, which is a problem since there is a limit in the number of automations that can be created for a database.
Suggested solution
If we could add conditional actions within the repeating group it would give us the possibilty to create only one automation.
Thank you for considering
Pascal
  • Sep 7, 2024 9:41 PM UTC
Yes! This is a very much-needed feature! Also, we really need the ability to have more than 50 automations in a base.
In the meantime, for those people who are reading this thread in the future, all of this is currently only available with Make’s advanced automations for Airtable.
— ScottWorld, Expert Airtable Consultant
I was about to post about this Product Idea/Feature request, but found your post @Pascal_Gallais- instead!
Pushing and giving Kudos for more visibility. This would be an absolute game-changer.
