Print Blocks (Matrix)
I have been working on creating a Marketing Calendar with Month, and a generic type as the columns and rows respectively using the ‘Matrix Block’ for my current project. However, I would also like to be able to print the block, but currently there is no option to print. I’ve worked around this by printing the webpage as a PDF and resizing to fit within a page, but a more natural way of doing this would be helpful.
Thank you.
  • January 27, 2020
Has anyone from Airtable responded about the development of the Matrix Block? Exportability or sharing? It would provide the utility that users require to craft and collaborate using that tool.
  • February 16, 2020
Hi Airtable,
I think the Matrix block is great. I too would like some way of exporting from the matrix block though, as it is kinda lonely sitting there showing lovely output and no way to share!
I would also like a bit more functionality, e.g. being able to select which field populates the matrix quadrants. Currently it’s fixed at the primary field, but that isn’t always the field most useful for a matrix.
Thanks,
Laura
