Print Blocks View
It’d be great if you could print the views of blocks. When you hit print now, it just prints the view of the main table/grid you’re in, not the full screen block you’re currently viewing. This would be a very useful addition!
I need this feature. I am paying so much money on this app and I cannot even download or print the timeline block I am using for an assignment in my doctoral course!
Would be enough to do a screenshot?
Agreed. This is an incredibly easy fix that needs to be taken care of. We have to pay for the blocks feature, so we should be able to print them.
  • August 27, 2019
This feature needs to be bumped up the pipeline. It is part of the premium plan and also a very simple but crucial feature. Not sure why they’re not addressing this. Its truly a bottleneck for a lot of things and deters the user from relying on the blocks and leaving no option but use another method.
Christopher_War
Yes completely agree. I want to create a report from my Blocks.
  • October 4, 2019
Another vote yes for this. I have been using blocks to create a visual dashboard of our data and being unable to share or print anything almost defeats the purpose if it can’t be shared outside of airtable.
I am currently on a free trial with the intention of upgrading for our business. Without the ability to print the blocks functions, though, it now seems unlikely.
Mohamed_Swella1
This is a very easy feature to add. In addition, the blocks should also have the ability to show the values.
i.e.: when having a chart block (pie chart or bar chart), I don’t have to hover the mouse on the item to see the value, it can be written inside the pie chart or on top of the bar chart.
We are also in need of the ability to print out the timeline views.
