PRODUCT SUGGESTION FOR FORMS: Hidden fields & hidden prefill fields that actually submit
Show first post
  • February 2, 2022
I use forms to have users submit data to my base. After having done A LOT of research I cannot believe there is no native way to set up a form with hidden fields. This is so obviously needed and wanted by many people that it seems like an intentional omission. @Airtable Is this on your roadmap? Is there a workaround or am I forced to use yet another tool to create a working form? Thanks :pray:
I am pretty sure they intended the ‘when a form is submitted’ trigger to solve for this
  • February 3, 2022
@Rebecca_Elam the automation does not work for the use case most people need. the hidden fields are set by custom variables in the URL. When the user hits submit these are gone and as such these cannot be passed on to the automation for parsing.
between conditional automations and the when a form is submitted trigger I cant figure any use case that would not already be solved in this area.
  • February 4, 2022
@Rebecca_Elam I appreciate the positive attitude but i dont see how it can work because hidden fields are not posted by the form and as such cannot be picked up by the “when a form is submitted” automation. it seems I’m not the only one as you can see here : Prefill a hidden form field - #53 by sic
Put the parameters you would have put in the url in the automation.
  • February 4, 2022
Sometimes people want to use the same form with different hidden prefills, so an automation based on when the form is submitted will not work. People may also need all of their automation slots for different things, and not have enough automation slots available to fill in values for records created via forms.
There are third party systems that offer hidden prefills. However, this thread is a product suggestion about making this feature native to Airtable.
solved!!!
Thank you so much!!! :star_struck:
Thank you and your team! Many people will be very happy about this.
  • March 8, 2024
I think this just got solved in the latest update, but it's behind a business plan paywall...
JustinTracey
  • March 21, 2024
Hi Scott,
I totally agree with you and I'm experiencing the same problem
I work for a charity for ex-offenders on parole and before the form they fill  in is submitted certain confidential information must be submitted to but there no way of keeping it hidden. I really don't want to create two forms.  Staff are already overworked with huge case loads- I'm trying to create work flows and risk assessments and evaluations that save them work- not make more work for them.
  • March 22, 2024
@JustinTracey just in case you’re not aware of this solution, Fillout was my work-around for Airtable not having this functionality.  Best of luck helping the charity, you’re doing good purposeful work.
