Sort/Filter on Mobile Device
Forum|alt.badge.img+9
While it seems Airtable is a desktop-built application, many customers/clients use mobile. A fair limitation to using Airtable for our business is the ability for our prospects to use the Sort/Filter features for an embedded view on mobile. They simply can’t interact with the data unless they are at a PC…
  • February 15, 2019
+1. The embedded tables lose all functionalities in mobile view. I’d much rather have a non-responsive table then a non-functioning one.
Tagging onto this thread but will also see if I can get a reply from the Airtable folks directly. Is there any hope of having desktop functionality (sort, filter etc) available on mobile devices? It’s mission-critical for my application. Thanks
Following this discussion as well. I am working on a project where most, if not all, users will want to filter and sort data via a mobile device - particularly iPhone and Android smartphones.
ConnorTomasko
Following this discussion. Creating a directory by embedding a view on a webpage and most users will be on mobile. We need the search functionality as well as the ability to filter and sort within a view on mobile.
Forum|alt.badge.img+20
  • June 9, 2020
Hi @ConnorTomasko
Yes you are able to search , filter and group records on a mobile devise.
Mary Kay
ConnorTomasko
Hi @M_k,
I haven’t been able to when looking at an embedded view on a webpage on mobile. Is that what you’re referring to? If so, I would welcome direction so that I can adjust settings on my embedded view.
Connor
Following…this is insane that airtable got to $1b without a mobile solution
  • June 19, 2021
I don’t think this works for embedded views unfortunately though. I just ran into this a month or so ago and was pretty surprised.
I’m following this thread because I’m trying to understand when this feature will become available.
There was a previous discussion about this here: Any workaround for filter, group, and search on an embedded view in a mobile device? - #8 by ScottWorld
in which @ScottWorld mentioned that requesting the desktop version of an embedded view from your mobile browser will show the filter, sort, and search options.
while the solution mostly works, it could be a big inconvenience depending on how people are using the shared embedded view. Curious to know the reasoning behind the omission as well from the product team.
I think their only reasoning is what an Airtable employee told me: that their focus is primarily on the desktop experience, and mobile is not a priority for them.
In my opinion, this is extremely short-sighted & completely ridiculous, considering that the majority of Internet usage is done on mobile devices — and you can certainly bet that Google will be focusing primarily on mobile with their Airtable competitor Google Tables.
I am an expert Airtable consultant, and I have already lost 2 clients because Airtable’s mobile views & mobile embedded views do not work. These are 2 customers that Airtable lost as well, but Airtable doesn’t care because they weren’t enterprise customers.
Airtable does not traditionally listen to any user feedback unless the feedback comes from enterprise users, but I would still encourage everyone to keep emailing support@airtable.com about this & keep bugging them about this.
Not only are they hurting all of us with this decision, but they are also hurting themselves as their customers leave Airtable for other products.
It’s crazy that Airtable wouldn’t just spend the few hours necessary to fix this gigantic & glaring problem in the platform.
That is a big mistake from Airtable. If we can’t use filtering/searching on the mobile view we need to skip airtable and look for a different solutions. Mobile FIRST is the new era and even if only 30% of our visitors is using a smartphone filtering/searching should be possible and it still likes this is not the case.
A real needed feature that’s missing and for us having to decide if this is not coming or on a roadmap to skip airtable as a very welcome solution.
Jen_Pennington
It is now almost a year later and this issue still exists. I have a mission critical need for this to be working for firefighters in the field working on Wildland Fires. Most do not take laptops in the field. They take their Mobile devices. This does not even work on tablets either. Has anyone found a workaround for this or heard anything from Airtable? I did write to their support email as per Scott’s advice.
I think this is the perfect example of how little Airtable cares about its customers.
A poor workaround is to view Airtable in a tablet web browser if your tablet’s web browser gives you the option to “request desktop website”. You still won’t get a mobile experience, but you will get the full desktop experience shrunk down to the size of your tablet. Not everything will work properly, either.
A better workaround would be to create your own mobile front end to Airtable by using a portal tool like Glide, MiniExtensions.com, or Softr.io.
As an expert Airtable consultant, I am available for hire to help customers setup portals, so feel free to contact me if you have a budget for your project:
Otherwise, many people find that they need to leave Airtable & switch to a truly professional database platform such as Claris FileMaker Pro, which provides robust desktop & mobile environments. (I can also refer you to great FileMaker developers, if you contact me through my website.)
  • November 28, 2023
can anyone give recommendation of substitution that could work on mobile?
alpacox
  • April 18, 2024
Can’t believe this isn’t sorted yet!
