Timeline block will not UNDO if a duration is moved
  • March 26, 2018
  • 20 views
Aristeidis_Zagk
Forum|alt.badge.img+16
hey i have set up the timeline block to visualize starting-expire date for leasing contracts. although it looks very nice visually, when i moved the by accident the visualized bar of the duration, it changed of course the corresponding records, but i couldn’t UNDO. i am not sure if this is a bug, but currently i disabled this block to prevent accidental changes
Hey there! Undo support for timeline block is definitely on our todo list. In the meantime, you can press the Esc key while accidentally dragging a timeline record to cancel the interaction.
