Two Way Base Syncing
What is the proposed idea/solution?
...have an option that when your are syncing  from one base to another you can select to sync vice versa so your isnt designating records twice.
How does is solve the user problems?
...Reduces repetition especially on larger tables
How was this validated?
...meeting with airtable liaisons with my company who confirmed this is not possible and only work arounds are available.
Who is the target audience?
...Anyone syncing bases that need access to the base they are sending information too
