Upload images with copy and paste
I daily update a database of my stock by product in a ‘base’.
I would like to have for each row the product image.
Every row will then have: Product code, description, stock quantity, image of the product.
Is it possible to do such a thing?
The idea can have a separate database with product code and image. Airtable should then recognize the product code in my other base and show the picture.
Is there a way to have something like that?
Thanks,
Matteo
Yes, why not?
You can paste images this way:
You could automate it with Integromat.
  • February 1, 2019
Yes, why not?
Would be great to simply select the Attachments field and press CTRL + V to upload an image.
