We still need a simple TITLE CASE (PROPER) function alongside UPPER and LOWER
  • Mar 22, 2021 3:34 PM UTC
  • 18 replies
  • 422 views
Forum|alt.badge.img+14
Users have been calling for a simple TITLE CASE / PROPER function since 2016.
And I know, there is @Bill.French’s wonderful script - Field Tweaker - that allows you to reformat a field as either UPPER, LOWER, or TITLE CASE.
However, the script doesn’t work when the field is a computed field, as it is in my case.
The fields I need text formatting control over are computed from different sources. I need versions of those fields that are UPPER CASE - which is easily achieved via the UPPER() function - but I also need TITLE CASE versions (for reasons I don’t want to bore anyone with).
Again, if there was a standard PROPER() function in Airtable, this would be a piece of cake.
I am sure I am not alone with this request.
Joe_Svingala
Forum|alt.badge.img+13
  • Mar 23, 2021 6:54 PM UTC
100% Agreed!
I ended up working around the issue you are encountering with the calculated field by creating an automation that would take my calculated field & re-enter it in another field as plain text - I then use Field Tweaker to Proper Case my entries. The problem with this is that I am then waiting for the script to be applied across 10,000+ lines, rather then the formula tackling it from the start.
Very much needed! 80 views in two weeks, help us Airtable!
Forum|alt.badge.img+7
I’ll add to the chorus, would love this functionality.
Yes please, I just imported a bunch of data and realize it’s all screwy and need proper caps etc.
  • Jul 29, 2021 9:09 PM UTC
@Markus_Wernig @Joe_Svingala @Miles_Mattison @Christopher_Cantrall @Curtis_Gabhart_CCIM you can use the formula below (instead of creating many columns to achieve this):
REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(LOWER({YOUR FIELD NAME}), "^a", "A"), "^b", "B"), "^c", "C"), "^d", "D"), "^e", "E"), "^f", "F"), "^g", "G"), "^h", "H"), "^i", "I"), "^j", "J"), "^k", "K"), "^l", "L"), "^m", "M"), "^n", "N"), "^o", "O"), "^p", "P"), "^q", "Q"), "^r", "R"), "^s", "S"), "^t", "T"), "^u", "U"), "^v", "V"), "^w", "W"), "^x", "X"), "^y", "Y"), "^z", "Z"), " a", " A"), " b", " B"), " c", " C"), " d", " D"), " e", " E"), " f", " F"), " g", " G"), " h", " H"), " i", " I"), " j", " J"), " k", " K"), " l", " L"), " m", " M"), " n", " N"), " o", " O"), " p", " P"), " q", " Q"), " r", " R"), " s", " S"), " t", " T"), " u", " U"), " v", " V"), " w", " W"), " x", " X"), " y", " Y"), " z", " Z")
My gosh! Thanks a lot!
Karlstens
Forum|alt.badge.img+24
  • Dec 5, 2021 9:12 PM UTC
That’s impressive, and yet somehow it makes me both happy and sad at the same time.
Forum|alt.badge.img+11
Apologies in advance if any of this doesn’t make sense, I’ve been playing with scripting, automations, and formulas for the past 6 hours.
I’m not sure exactly what your need is for Title Case, but I was determined to fix my issue regarding Title Case using a formula.
One of my bases is an ATS where people fill out an application/pre-screening questionnaire that has separate fields for First Name and Last Name. I was using a CONCANTENATE formula to have a Full Name field, but sometimes applicant’s input their names in all caps or all lower case.
The Formula:
UPPER(LEFT({First Name}, 1)) & LOWER(MID({First Name}, 2, 20)) & " " & UPPER(LEFT({Last Name}, 1)) & LOWER(MID({Last Name}, 2, 20))
I used UPPER to capitalize and LEFT to grab the first letter of the word in the First Name field. I then used LOWER to uncapitalize and MID to start with the second letter of the word in the First Name field. The 20 is probably more characters than I will ever have in that field, but I set it to pull apply to the next 20 letters just in case. Then I used ‘& " " &’ to add a space and then followed the exact same formula to edit the First Name fields and applied it to the Last Name fields.
Depending on your use case, you’ll probably need to edit other fields or formulas, or add/change some parameters, but I hope this is helpful!
  • Jan 15, 2022 11:07 PM UTC
Thanks so much for this! Now if we can just get a simpler function in Airtable …
  • Jan 22, 2022 12:32 PM UTC
The Formula:
Thank you for this! Extremely helpful and I hope I don’t run into a name where there is more than 20 characters in either parameter
Forum|alt.badge.img+12
  • Mar 2, 2022 9:06 AM UTC
Thanks for this function, @gxjansen! I created my own modified version of it that’s a little more flexible—the original formula wasn’t able to handle symbols like parentheses, hyphens, and quotation marks, which my new formula does. Additionally, I cut the number of REGEX_REPLACE() functions in half by using multi-option capturing groups. Now only a single REGEX_REPLACE() function is needed for each letter of the alphabet.
Example
Here’s a super contrived example:
The “trick” to “being” [healthy] (and happy!) and ‘wise’ {forever} ‘we promise’
Here’s what you would get with the old formula (i.e. many words aren’t capitalized):
The “trick” To “being” [healthy] (and Happy!) And “wise” {forever} ‘we Promise’
Here’s what you get with the new formula:
The “Trick” To “Being” [Healthy] (And Happy!) And “Wise” {Forever} ‘We Promise’
Complete function:
Copy and paste the complete function below into your formula, and replace {YOUR FIELD NAME HERE} with the correct field name.
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
REGEX_REPLACE(
{YOUR FIELD NAME HERE},
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)a", "$1A"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)b", "$1B"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)c", "$1C"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)d", "$1D"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)e", "$1E"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)f", "$1F"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)g", "$1G"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)h", "$1H"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)i", "$1I"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)j", "$1J"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)k", "$1K"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)l", "$1L"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)m", "$1M"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)n", "$1N"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)o", "$1O"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)p", "$1P"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)q", "$1Q"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)r", "$1R"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)s", "$1S"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)t", "$1T"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)u", "$1U"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)v", "$1V"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)w", "$1W"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)x", "$1X"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)y", "$1Y"),
"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)z", "$1Z")
If the formatting of the formula is giving you trouble, here’s the formula compressed onto a single line:
REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE({YOUR FIELD NAME HERE},"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)a", "$1A"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)b", "$1B"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)c", "$1C"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)d", "$1D"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)e", "$1E"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)f", "$1F"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)g", "$1G"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)h", "$1H"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)i", "$1I"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)j", "$1J"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)k", "$1K"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)l", "$1L"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)m", "$1M"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)n", "$1N"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)o", "$1O"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)p", "$1P"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)q", "$1Q"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)r", "$1R"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)s", "$1S"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)t", "$1T"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)u", "$1U"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)v", "$1V"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)w", "$1W"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)x", "$1X"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)y", "$1Y"),"(^| |\(|\[|\{|-|\\"|[ ^]\'|“|‘)z", "$1Z")
Notes
Each regex function has the following capture group:
This is a list of symbols, separated by the pipe symbol (|) which means “or”. You can add or remove symbols as you please, always separating them with a pipe. Here’s the list of symbols I’m currently matching on with explanations:
^        ← Line start
\(       ← Parentheses
\[       ← Square Bracket
\{       ← Curly Brace
-        ← Hyphen, ensures that hyphenated words are properly capitalized, e.g. Empty-Handed
\"       ← Double quote
[ ^]\'   ← Single quote. must be preceded by a space or at line beginning, this is to avoid matching apostrophes
 “       ← Double curly quote
 ‘       ← Single curly quote
Important: this formula no longer converts the original text to lower case before capitalizing. I made this decision because there are many cases when doing this would result in incorrect capitalization. A couple examples:
  • Family names: McCabe would become Mccabe if we converted to lowercase first
  • Common acronyms: LED, DIY, ATM would become Led, Diy, Atm
If the input text you’re dealing with has a lot of ALL-CAPS you want to get rid of and you don’t care about incorrect capitalizations like the one above, you can put the initial lowercase transformation back in by adding LOWER() around the field name, like so:
LOWER({YOUR FIELD NAME HERE})
  • Mar 16, 2022 10:13 PM UTC
Chiming in to ditto this request.
  • Apr 6, 2022 1:23 PM UTC
The Formula:
Is there a way to adjust this for situations where there is a space in the {First Name} field? Such as if they had a first and middle name entered there, both in all caps, and I wanted to correct it?
Thank you!
  • Sep 6, 2023 3:46 PM UTC
Please please please implement this @ Airtable
Forum|alt.badge.img+8
  • Jul 11, 2024 11:42 PM UTC
@Markus_Wernig
Preface: Though I'm late to the thread, I share your consternation (as do many).  After an utterly disappointing attempt to have Airtable AI generate a formula that would efficiently solve this formatting pain point, which produced invalid and baffling results (including generating formulae functions that don't exist in AT, and then generating invalid "fix suggestions" to correct its own errors and fabrications), I gave up on elegance and went back to my layman, multiple formula method—I call it chunk-n-clunk. It's not particularly streamlined or pretty, but hey, it works. I'm including it here in case anyone else in the "no code" camp just needs something that gets the job done.
Our Use Case: My company (a music publisher and record administrator) receives a continual influx of large datasets from multiple external sources. These sources return specific values in UPPER CASE, but we use and display said values in Title Case. Automations are not a viable solution because of volume, and the limited text formatting capabilities.
Solution: 3-formula sequence, where the 3rd formula results in text displayed in Title Case.
  • {FORMULA 1}
LOWER({FIELD WITH UPPERCASE TEXT}) // RESULT: "SONG TITLE HERE" -> "song title here"
  • {FORMULA 2}
UPPER(LEFT({FORMULA 1}, 1)) & LOWER(MID({FORMULA 1}, 2, LEN({FORMULA 1}) - 1)) // RESULT: "song title here" -> "Song title here"
  • {FORMULA 3}
REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE(REGEX_REPLACE({FORMULA 2}, " a", " A"), " b", " B"), " c", " C"), " d", " D"), " e", " E"), " f", " F"), " g", " G"), " h", " H"), " i", " I"), " j", " J"), " k", " K"), " l", " L"), " m", " M"), " n", " N"), " o", " O"), " p", " P"), " q", " Q"), " r", " R"), " s", " S"), " t", " T"), " u", " U"), " v", " V"), " w", " W"), " x", " X"), " y", " Y"), " z", " Z") // RESULT: "Song title here" -> "Song Title Here"
*Others have suggested the REGEX_REPLACE function in various iterations, so thanks to all who gave examples. I pared the above down from previous examples, and preceded it with the other 2 formulae to get it to work as expected for our use-case.
Conclusion: If you have a volume of varied text strings that ultimately needs to be formatted in Title Case (AKA Proper Case), you can achieve it in 3 formula steps by
  1. Converting all text of your {FIELD WITH UPPERCASE TEXT} (or {Field with Text}, however it appears) to lowercase: {FORMULA 1}
  2. Capitalizing the first letter of the first word of the preceding formula's calculation: {FORMULA 2}
  3. From {FORMULA 2}'s calculation, replacing any single space followed by a lowercase letter with a single space followed by a capital letter: {FORMULA 3}
There is probably a better way to achieve this, but I couldn't find one. SO, if you're stuck like I was, hopefully this can help.
Cheers!
  • Aug 9, 2024 7:34 PM UTC
I just wanted to add a note that I thought I found a simpler solution to this problem by using the uppercase flag in the Regex replacement string like so:
\U$1
but sadly this isn't supported by Airtable's Regex functions. For reference, Airtable uses the RE2 Regex library. Thankfully the solution I posted previously still works! (I needed it today, lol)
Dec 20, 2024. So Airtable doesn't listen to their customers?
  • Feb 7, 2025 10:21 PM UTC
Hey folks, this is the formula I made to convert a text string to simple title case:
REPLACE(
LOWER(
TRIM(
{Name Text})),
1,1,
UPPER(
LEFT({Name Text},1)))
It does the following, in order:
  • Trim extra spaces from the beginning and end of the text string
  • Convert the whole string to lower case
  • Replace the first letter of the string with an upper case version of itself
It won't do complicated title case (McDonnell, Van Der Holt, etc). If I have the time I'll update with some fancy search and replace for those things.
It's simple enough that I'm going to deploy it wherever I need title case, but it sure would be nice if there was a one-step formula available instead.
